Ruby track rod pin
Dave,
Regarding your comments to Derek and Reckless, I had a very similar thing recently and found the problem to be binding/sticking rear dampers.
I think the problem may have been that the damper nuts were overtight (as Derek suggests), but also the dampers themselves were quite dirty and 'gummed up' with road dirt. After disassembling and cleaning the friction dampers in Petrol I reassembled and adjusted. Now everything is back to normal.
If you need an exploded view then email me and I can send it to you.
Hope this helps you?
Matt
Ruby track rod pin - by Pricey - 12-08-2017, 12:20 PM
RE: Ruby track rod pin - by Matt_Harnden - 12-08-2017, 02:27 PM
RE: Ruby track rod pin - by peter burton - 12-08-2017, 08:48 PM
RE: Ruby track rod pin - by Mark Dymond - 13-08-2017, 01:53 AM
RE: Ruby track rod pin - by Mark R - 13-08-2017, 09:41 AM
RE: Ruby track rod pin - by Derek Sheldon - 13-08-2017, 10:38 AM
RE: Ruby track rod pin - by Reckless Rat - 13-08-2017, 10:40 AM
RE: Ruby track rod pin - by Pricey - 13-08-2017, 11:45 AM
RE: Ruby track rod pin - by Derek Sheldon - 13-08-2017, 09:35 PM
RE: Ruby track rod pin - by Matt_Harnden - 14-08-2017, 04:21 PM
RE: Ruby track rod pin - by Pricey - 02-09-2017, 07:46 AM
