Leaky distributor cap
(14-01-2020, 10:50 PM)Adrian Payne Wrote: Many thanks for the suggestions.
I have read somewhere that if a spark tracks across an oily surface then a carbon track is left behind which can never be removed. Most dewatering products seem to lubricate as well so could they be oil based?
I think I will try the varnish first and see how that goes.
Many thanks.
Adrian.
Any varnish type product is likely to cause problems. After a few years it is likely to slightly crack, peal, etc. And it's then difficult to remove the 'varnish'. Holts wet-start used to do this, it was a very temporary fix. Holts damp-start was an oily water repellant and never gave problems. Thirty-odd years ago I used WD40 and Duck oil on thousands of old distributor caps with long lasting success.
If you can see a carbon track, just sandpaper it away, then spray.
Leaky distributor cap - by Adrian Payne - 14-01-2020, 03:28 PM
RE: Leaky distributor cap - by Robert Foreman - 14-01-2020, 08:50 PM
RE: Leaky distributor cap - by Greig Smith - 14-01-2020, 08:51 PM
RE: Leaky distributor cap - by Adrian Payne - 14-01-2020, 10:50 PM
RE: Leaky distributor cap - by Ruairidh Dunford - 14-01-2020, 11:02 PM
RE: Leaky distributor cap - by Adrian Payne - 14-01-2020, 11:11 PM
RE: Leaky distributor cap - by Ruairidh Dunford - 14-01-2020, 11:23 PM
RE: Leaky distributor cap - by andrew34ruby - 15-01-2020, 10:38 AM
RE: Leaky distributor cap - by Robert Leigh - 15-01-2020, 11:43 AM
RE: Leaky distributor cap - by Colin Swinbourne - 15-01-2020, 06:59 PM
RE: Leaky distributor cap - by Ruairidh Dunford - 15-01-2020, 08:32 PM
RE: Leaky distributor cap - by Nick Turley - 15-01-2020, 10:07 PM
RE: Leaky distributor cap - by Bob Culver - 15-01-2020, 11:04 PM
