Leaky distributor cap
Adrian,
 some Blic distributor caps are a brown and some a reddish colour. I suspect the reddish ones were painted with a red insulating varnish when new.
Once you have cooked the cap and removed as much moisture as you can. You can  use a hygrometer to check how dry you have got it.
  Then I would try a high voltage insulating varnish. Varnish inside and out and when completely dry clean the contacts inside.
   Hope this helps.
Leaky distributor cap - by Adrian Payne - 14-01-2020, 03:28 PM
RE: Leaky distributor cap - by Robert Foreman - 14-01-2020, 08:50 PM
RE: Leaky distributor cap - by Greig Smith - 14-01-2020, 08:51 PM
RE: Leaky distributor cap - by Adrian Payne - 14-01-2020, 10:50 PM
RE: Leaky distributor cap - by Ruairidh Dunford - 14-01-2020, 11:02 PM
RE: Leaky distributor cap - by Adrian Payne - 14-01-2020, 11:11 PM
RE: Leaky distributor cap - by Ruairidh Dunford - 14-01-2020, 11:23 PM
RE: Leaky distributor cap - by andrew34ruby - 15-01-2020, 10:38 AM
RE: Leaky distributor cap - by Robert Leigh - 15-01-2020, 11:43 AM
RE: Leaky distributor cap - by Colin Swinbourne - 15-01-2020, 06:59 PM
RE: Leaky distributor cap - by Ruairidh Dunford - 15-01-2020, 08:32 PM
RE: Leaky distributor cap - by Nick Turley - 15-01-2020, 10:07 PM
RE: Leaky distributor cap - by Bob Culver - 15-01-2020, 11:04 PM
