Compression test?
Steve,
There are just so many unknowns with an engine which was not previously running (?) it's difficult to know where to start.
You might find the attached check list helpful, it covers most of the possible candidates (though it was written with an SU carb in mind, so you may have to think about your Zenith a bit too).
.xlsx   A7 Doesn't Start.xlsx (Size: 18.4 KB / Downloads: 34)
Compression test? - by Graham Honnor - 09-10-2017, 12:11 PM
RE: Compression test? - by Martin Prior - 09-10-2017, 12:21 PM
RE: Compression test? - by Graham Honnor - 09-10-2017, 12:28 PM
RE: Compression test? - by Bob Culver - 10-10-2017, 06:00 AM
RE: Compression test? - by Chris KC - 10-10-2017, 06:36 PM
RE: Compression test? - by Derek Simmons - 11-10-2017, 03:55 PM
RE: Compression test? - by Chris KC - 11-10-2017, 06:45 PM
RE: Compression test? - by Graham Honnor - 11-10-2017, 07:09 PM
RE: Compression test? - by stevenm - 13-01-2020, 07:32 PM
RE: Compression test? - by bob46320 - 13-01-2020, 08:06 PM
RE: Compression test? - by dickie65 - 13-01-2020, 09:08 PM
RE: Compression test? - by stevenm - 14-01-2020, 10:44 AM
RE: Compression test? - by Chris KC - 14-01-2020, 11:02 AM
RE: Compression test? - by stevenm - 14-01-2020, 12:56 PM
RE: Compression test? - by Nick Turley - 14-01-2020, 07:14 PM
RE: Compression test? - by Bob Culver - 14-01-2020, 08:49 PM
RE: Compression test? - by John Mason - 14-01-2020, 09:44 PM
RE: Compression test? - by stevenm - 15-01-2020, 10:53 AM
RE: Compression test? - by Bob Culver - 15-01-2020, 07:51 PM
RE: Compression test? - by stevenm - 16-01-2020, 12:42 PM
RE: Compression test? - by AustinWood - 16-01-2020, 02:38 PM
RE: Compression test? - by Colin Wilks - 16-01-2020, 07:26 PM
RE: Compression test? - by stevenm - 16-01-2020, 09:15 PM
RE: Compression test? - by Colin Wilks - 16-01-2020, 09:36 PM
RE: Compression test? - by Alan - 16-01-2020, 09:48 PM
RE: Compression test? - by Colin Wilks - 16-01-2020, 10:25 PM
RE: Compression test? - by Tony Press - 17-01-2020, 02:26 AM
