Compression test?
Hi Steve,
Pull the spark plugs out and put a teaspoon of petrol into the cylinders put the plugs back in and have a go at starting.
If it runs then stops you have no fuel getting in, you might find it will start and pull fuel through and keep running.
Compression test? - by Graham Honnor - 09-10-2017, 12:11 PM
RE: Compression test? - by Martin Prior - 09-10-2017, 12:21 PM
RE: Compression test? - by Graham Honnor - 09-10-2017, 12:28 PM
RE: Compression test? - by Bob Culver - 10-10-2017, 06:00 AM
RE: Compression test? - by Chris KC - 10-10-2017, 06:36 PM
RE: Compression test? - by Derek Simmons - 11-10-2017, 03:55 PM
RE: Compression test? - by Chris KC - 11-10-2017, 06:45 PM
RE: Compression test? - by Graham Honnor - 11-10-2017, 07:09 PM
RE: Compression test? - by stevenm - 13-01-2020, 07:32 PM
RE: Compression test? - by bob46320 - 13-01-2020, 08:06 PM
RE: Compression test? - by dickie65 - 13-01-2020, 09:08 PM
RE: Compression test? - by stevenm - 14-01-2020, 10:44 AM
RE: Compression test? - by Chris KC - 14-01-2020, 11:02 AM
RE: Compression test? - by stevenm - 14-01-2020, 12:56 PM
RE: Compression test? - by Nick Turley - 14-01-2020, 07:14 PM
RE: Compression test? - by Bob Culver - 14-01-2020, 08:49 PM
RE: Compression test? - by John Mason - 14-01-2020, 09:44 PM
RE: Compression test? - by stevenm - 15-01-2020, 10:53 AM
RE: Compression test? - by Bob Culver - 15-01-2020, 07:51 PM
RE: Compression test? - by stevenm - 16-01-2020, 12:42 PM
RE: Compression test? - by AustinWood - 16-01-2020, 02:38 PM
RE: Compression test? - by Colin Wilks - 16-01-2020, 07:26 PM
RE: Compression test? - by stevenm - 16-01-2020, 09:15 PM
RE: Compression test? - by Colin Wilks - 16-01-2020, 09:36 PM
RE: Compression test? - by Alan - 16-01-2020, 09:48 PM
RE: Compression test? - by Colin Wilks - 16-01-2020, 10:25 PM
RE: Compression test? - by Tony Press - 17-01-2020, 02:26 AM
