  • 1 Vote(s) - 1 Average
King pin eye faces on stub and beam axles.
Chris KC   thanks for that will look into tap seat cutter.  What did you use for thrust washers?  Have seen some oilite available 21/32 ID (1/64 bigger than 5/8 king pin) X 1 1/4" (can turn this down to 1 1/8" required) but only 3/32" thick...perhaps 2 together?
Bull Motif supply oilite for A30/35......the man on the phone said brass!! dimensions given were 5/8 X 1 1/4" X 4mm
Part No: ZFS016
[Image: ZFS016.jpg]
Oilite Washer(special washer fits on king pin shaft)
£2.95
That seems to equate to the oilite manufacturers AW112002 21/32" X 1 1/4" X 3/32" @ £2.16 from Bearingboys.
Or even £1.28 from "Get Your Bearings"   £6.34 including vat and delivery 1st post.  So 4 of them at £10.94
Dennis
RE: King pin eye faces on stub and beam axles. - by Dennis Nicholas - 28-11-2017, 07:19 PM
