Engines
Hi Jim,Welcome to the forum.
I've never tried to fit a different engine to a seven but it used to be quite common to fit Ford 8 and 10's in the '50's.
I have seen BMC A series ,Reliant and Riley 9 engines fitted too so it is possible.
You would have to move the front cross member back to slot the engine and gearbox in I guess and correct the associated problems of doing so. ( Brake cross shaft )
Engines - by james_ellis - 11-01-2020, 09:33 PM
RE: Engines - by Austin in the Shed - 12-01-2020, 09:36 AM
RE: Engines - by Paul N-M - 12-01-2020, 10:39 AM
RE: Engines - by Chris KC - 12-01-2020, 10:52 AM
RE: Engines - by Parazine - 12-01-2020, 12:54 PM
RE: Engines - by Ian Williams - 12-01-2020, 07:52 PM
RE: Engines - by Stuart Giles - 13-01-2020, 11:19 AM
RE: Engines - by Ian Williams - 13-01-2020, 07:51 PM
RE: Engines - by Hedd_Jones - 13-01-2020, 10:12 PM
RE: Engines - by james_ellis - 20-01-2020, 04:50 PM
RE: Engines - by Tony Press - 20-01-2020, 10:19 PM
RE: Engines - by Tony Griffiths - 22-01-2020, 10:58 AM
RE: Engines - by Reckless Rat - 22-01-2020, 03:02 PM
RE: Engines - by Austin in the Shed - 22-01-2020, 03:36 PM
RE: Engines - by Steve Jones - 22-01-2020, 04:09 PM
RE: Engines - by james_ellis - 24-01-2020, 05:37 PM
RE: Engines - by A G Wood - 26-01-2020, 09:50 AM
RE: Engines - by Stuart Giles - 26-01-2020, 02:24 PM
RE: Engines - by jpsmit - 26-01-2020, 03:18 PM
