Pot & Trunnion Propshaft Repair?
(28-11-2017, 08:40 AM)Mark R Wrote: There's a pot and pin on eBay listed in the last couple of days, as usual, no connection.
https://www.ebay.co.uk/itm/Austin-7-seve...SwEaBaHHRL
Regarding balance, I had a 1931 saloon which vibrated horribly above 40mph even if coasting in neutral, I filed out the holes slightly in the correct direction and set it up with a dial test indicator to get it running true. It made a massive difference and was well worth doing.
Thanks Mark. I have 3 pots already so no problem there. Good tip though re balancing - thank you.
Pot & Trunnion Propshaft Repair? - by Chris KC - 22-11-2017, 11:18 AM
RE: Pot & Trunnion Propshaft Repair? - by Mark R - 28-11-2017, 08:40 AM
RE: Pot & Trunnion Propshaft Repair? - by Chris KC - 28-11-2017, 09:08 AM
RE: Pot & Trunnion Propshaft Repair? - by David.H - 03-12-2017, 11:58 AM
RE: Pot & Trunnion Propshaft Repair? - by David.H - 03-12-2017, 06:24 PM
RE: Pot & Trunnion Propshaft Repair? - by JonE - 15-01-2018, 09:52 AM
