06-01-2020, 01:31 PM
It is not an automatic respray, well only if you want to make it perfect.
It also has a lot of caused beyond moisture in the airline (and can in fact be solvent as well as moisture.
What we advise customers with this problem on boats is to wait for the warmer weather. When you are sure all the moisture has blistered out, lightly flat and apply a coat of Varnish. (A clear one like we sell at Craftmaster rather than a polyurethane that will yellow).
It isn't impossible to recover the situation but it will require a fair bit of work
