Gear type pump pressure relief valve
(03-01-2020, 06:29 PM)Austin in the Shed Wrote: So,Is it necessary to fit a larger pump than the 7 one if you cure the engines inherent "leaks ",Cam bushes/crank nut  ?
Not sure but I don't want to gamble.
A gear pump delivers both pressure and volume.
I might do some crude maths to compare the two!
C
RE: Gear type pump pressure relief valve - by Charles P - 03-01-2020, 06:48 PM
