Cylinder compression variances
Leakdown test is most accurate and revealing where leaks are , rings ,  air in breather ,  valves ,  air in carb. or exhaust , gasket ,  air in radiator , or between cylinders.  I had 10% leakdown , all past rings , will be doing Total Seal rings during Winter teardown .   STEVE
<p><br></p>
Cylinder compression variances - by Rod Shaw - 31-12-2019, 03:38 PM
RE: Cylinder compression variances - by Rod Shaw - 31-12-2019, 05:57 PM
RE: Cylinder compression variances - by steve anderson - 31-12-2019, 08:31 PM
RE: Cylinder compression variances - by Rod Shaw - 01-01-2020, 08:46 PM
