Warning [2] Undefined array key "fragment" - Line: 1494 - File: inc/class_parser.php PHP 8.1.31 (Linux)
/showthread.php 913 build_postbit
Warning [2] Undefined array key "query" - Line: 1505 - File: inc/class_parser.php PHP 8.1.31 (Linux)
Warning [2] Undefined array key 1 - Line: 1510 - File: inc/class_parser.php PHP 8.1.31 (Linux)
Warning [2] Undefined array key 0 - Line: 1587 - File: inc/class_parser.php PHP 8.1.31 (Linux)
Warning [2] Undefined array key "v" - Line: 1591 - File: inc/class_parser.php PHP 8.1.31 (Linux)
crownwheel to pinion setup
Hi all,
Any input welcome
I'm trying to mate my crownwheel and pinion together and would appreicate a little adivce.  The CW and P are both new, brought as a set, but not sure if they are were "matched".  Anyway I've tried to get the markings as shown in the Woodrow manual but I'm not sure I fully understand what I'm doing.  I've attached link to a video that shows the contact patch.  I've also attached a photo with the contact patch marked in pink (the blue didn't come up well in the photo).   I think the contact patch is too close to the end of the tooth and needs to be moved back slightly  closer to the base of the pinion.
My interpretation of the sketches in Woodrow and the comments around adjustments is that this contact patch shows that the pinion needs to moved nearer to the crownwheel by removing shims.  Is this correct or am I getting in 180 degrees wrong?
If it is correct then I'm in trouble as I've got no shims to remove.  If I add shims it seems to move the contact patch ever so slightly closer toward the axel line.
One last question.  Am I correct in saying that if shims are added to move the P away from the CW then the backlash will increase and the adjusters need to be moved to push the CWtoward the P and vice versa if shims are removed.
Steve & Tate Davidson
Perpetual Amateur Austineers
crownwheel to pinion setup - by steve davidson - 29-12-2019, 07:43 AM
RE: crownwheel to pinion setup - by Howard Wright - 29-12-2019, 09:03 AM
RE: crownwheel to pinion setup - by Bob Culver - 29-12-2019, 08:16 PM
RE: crownwheel to pinion setup - by Tony Press - 30-12-2019, 06:31 AM
RE: crownwheel to pinion setup - by Bob Culver - 30-12-2019, 06:45 AM
RE: crownwheel to pinion setup - by Stuart Giles - 30-12-2019, 01:37 PM
RE: crownwheel to pinion setup - by Tony Press - 30-12-2019, 10:00 PM
RE: crownwheel to pinion setup - by Bob Culver - 31-12-2019, 09:30 AM
