  • 1 Vote(s) - 4 Average
bantam turbo
(28-12-2019, 09:30 PM)steve anderson Wrote: Well the Bantam with Austin 7 engine is still doing fine , ran at Bonneville Salt Flats with 82 MPH .  Still won't pull 3rd and 4th gear yet , so working on new cam profile with 112 / 114  lobe split to be built .  Going to alcohol next year so will step up injectors to 55# .. There some other updates in the works , oil line reroute ,  maybe water entering head first , it goes in at 2 spots on head plus front and back of block on port side ..  Head gasket is now solid copper , seals better and reusable , block to crankcase gasket steel and reusable .  There are 2 studs from bottom of block to top of crankcase on cam side to help secure they stay together     STEVE
Two Austin 7 sports models were offered in January 1924, the Sports and the Brooklands Super-sports. The Brooklands Super-sports was a replica of Gordon England's record-breaker. Each car was sold with a Brooklands certificate proving a speed of 80 miles (128.75 km) per hour.
In 1931 the supercharged Austin 7 Works Streamlined Special reached 102 mph at Brooklands.
Still a way to go !
bantam turbo - by steve anderson - 05-04-2019, 02:49 AM
RE: bantam turbo - by bob46320 - 05-04-2019, 06:33 AM
RE: bantam turbo - by Colin Reed - 05-04-2019, 10:07 AM
RE: bantam turbo - by jansens - 05-04-2019, 07:56 PM
RE: bantam turbo - by steve anderson - 06-04-2019, 12:04 AM
RE: bantam turbo - by Stuart Giles - 06-04-2019, 08:40 AM
RE: bantam turbo - by steve anderson - 06-04-2019, 02:31 PM
RE: bantam turbo - by steve anderson - 23-05-2019, 04:42 AM
RE: bantam turbo - by steve anderson - 28-12-2019, 09:30 PM
RE: bantam turbo - by Colin Reed - 28-12-2019, 09:54 PM
RE: bantam turbo - by steve anderson - 28-12-2019, 11:38 PM
RE: bantam turbo - by Tony Press - 29-12-2019, 02:25 AM
RE: bantam turbo - by steve anderson - 29-12-2019, 05:58 AM
