26-12-2019, 02:40 PM
It is no nuisance - no questions, no point to Forum!
Hmmm Are you sure the car is still 6 volt?
I suppose it is, if you have a 6 v battery. The battery determines the base line voltage of the system.
I would check the bulbs, coil and control box, and starter, to see if anything else has been changed.
If a 12v starter, that would explain the sluggish starting.
The 6v dynamo on the Seven is happy to generate 12, so I suppose a 12v dynamo will be ok generating 6, but other people will know more about this than I do.
6v dynamos suitable for the Big 7 pop up on flea bay from time to time.
