Valve guide seals on a seven?
Hi Jeff,
these seal are generally off the shelf by sizes or ones specifically made for OEM application. The ones we've been using require the valve guides to have the tops machined to allow the seal to lock on to the guide when pushed on. Discussion with your favored machine shop should be able to ascertain if they can find and install a suitable guide seal.
Stephen
Valve guide seals on a seven? - by Steve Bryant - 17-12-2019, 02:12 AM
RE: Valve guide seals on a seven? - by Bob Culver - 17-12-2019, 03:20 AM
RE: Valve guide seals on a seven? - by Chris KC - 17-12-2019, 05:57 AM
RE: Valve guide seals on a seven? - by Steve Bryant - 17-12-2019, 02:36 PM
