Valve guide seals on a seven?
I suggest unless you can think of an actual benefit, the current set-up which works quite well is better left alone. A7's don't as far as I'm aware suck much oil from the valve chest into the cylinders unless horribly worn, which if so is easily remedied. And there are a whole load of places I'd look before this to reduce oil consumption.
Valve guide seals on a seven? - by Steve Bryant - 17-12-2019, 02:12 AM
RE: Valve guide seals on a seven? - by Bob Culver - 17-12-2019, 03:20 AM
RE: Valve guide seals on a seven? - by Chris KC - 17-12-2019, 05:57 AM
