The bulbs are filament 6v 18W, supplied as part of the kit. They are more than bright enough. The cables you can see are the power leads to the two accumates - one for the Austin the other for the MG.
On a saloon the options for fitting front indicators are limited unless you're able to fit them in wing mounted sidelights. I have seen some cars with them fitted to the side of the rad shell but they seem to be very close together.
RE: What have you done today with your Austin Seven - by Reckless Rat - 14-12-2019, 05:43 PM
Users browsing this thread: 18 Guest(s)
