And then it went Bang
In a performance engine normal pattern block studs from some suppliers are not up to the job, you really need to ensure they are high enough grade to take the load or breakages are common in my experience. Charles your engine is blown isn't it? What sort of boost do you run? As we know the factory had this exact problem with their blown engines hence the stiffening gussets and extra studs.
And then it went Bang - by Charles P - 13-08-2017, 02:03 PM
RE: And then it went Bang - by Martin Prior - 13-08-2017, 02:16 PM
RE: And then it went Bang - by Dave Wortley - 13-08-2017, 02:19 PM
RE: And then it went Bang - by Derek Sheldon - 13-08-2017, 02:36 PM
RE: And then it went Bang - by Steve Jones - 13-08-2017, 02:54 PM
RE: And then it went Bang - by Charles P - 13-08-2017, 02:51 PM
RE: And then it went Bang - by Stuart Giles - 13-08-2017, 03:25 PM
RE: And then it went Bang - by Duncan Grimmond - 13-08-2017, 04:08 PM
RE: And then it went Bang - by Charles P - 13-08-2017, 04:18 PM
RE: And then it went Bang - by Speedex750 - 13-08-2017, 07:27 PM
RE: And then it went Bang - by Dave Prior - 13-08-2017, 07:38 PM
RE: And then it went Bang - by Tony Betts - 13-08-2017, 08:25 PM
RE: And then it went Bang - by Charles P - 13-08-2017, 08:33 PM
RE: And then it went Bang - by Tony Betts - 14-08-2017, 06:34 PM
RE: And then it went Bang - by Ian Williams - 13-08-2017, 09:18 PM
RE: And then it went Bang - by Charles P - 13-08-2017, 10:48 PM
RE: And then it went Bang - by Colin Reed - 13-08-2017, 09:50 PM
RE: And then it went Bang - by Colin Reed - 14-08-2017, 04:48 AM
RE: And then it went Bang - by Ian Williams - 14-08-2017, 06:58 AM
RE: And then it went Bang - by Charles P - 14-08-2017, 09:10 AM
RE: And then it went Bang - by Ian Williams - 14-08-2017, 09:35 AM
RE: And then it went Bang - by Derek Sheldon - 14-08-2017, 10:53 AM
RE: And then it went Bang - by Dave Wortley - 14-08-2017, 12:02 PM
RE: And then it went Bang - by Alan - 14-08-2017, 04:50 PM
RE: And then it went Bang - by Charles P - 14-08-2017, 05:39 PM
RE: And then it went Bang - by Austin in the Shed - 14-08-2017, 05:55 PM
RE: And then it went Bang - by Charles P - 14-08-2017, 05:57 PM
RE: And then it went Bang - by Austin in the Shed - 14-08-2017, 06:16 PM
RE: And then it went Bang - by dickie65 - 14-08-2017, 06:33 PM
RE: And then it went Bang - by Ruairidh Dunford - 14-08-2017, 06:53 PM
RE: And then it went Bang - by Tony Betts - 14-08-2017, 09:57 PM
RE: And then it went Bang - by Zetomagneto - 14-08-2017, 10:00 PM
RE: And then it went Bang - by Ian Williams - 14-08-2017, 10:06 PM
RE: And then it went Bang - by Ruairidh Dunford - 14-08-2017, 10:19 PM
RE: And then it went Bang - by Tony Betts - 14-08-2017, 11:24 PM
RE: And then it went Bang - by Charles P - 14-08-2017, 11:44 PM
RE: And then it went Bang - by Ian Williams - 15-08-2017, 12:22 AM
RE: And then it went Bang - by Ian Dunford - 15-08-2017, 12:29 AM
RE: And then it went Bang - by Ian Williams - 15-08-2017, 12:29 AM
RE: And then it went Bang - by Tony Betts - 15-08-2017, 06:39 PM
RE: And then it went Bang - by Charles P - 15-08-2017, 08:44 PM
RE: And then it went Bang - by Ian Williams - 15-08-2017, 08:54 PM
RE: And then it went Bang - by Charles P - 20-08-2017, 10:31 PM
RE: And then it went Bang - by Austin in the Shed - 29-09-2017, 06:47 PM
RE: And then it went Bang - by Tony Press - 20-08-2017, 11:29 PM
RE: And then it went Bang - by Colin Reed - 21-08-2017, 03:45 AM
RE: And then it went Bang - by Albert S - 21-08-2017, 08:29 AM
RE: And then it went Bang - by Tony Betts - 23-08-2017, 08:31 PM
RE: And then it went Bang - by Bob Culver - 23-08-2017, 07:41 AM
RE: And then it went Bang - by Mike Costigan - 23-08-2017, 08:50 PM
RE: And then it went Bang - by Tony Betts - 24-08-2017, 02:47 PM
RE: And then it went Bang - by Charles P - 29-09-2017, 11:49 PM
