Cylinder block sliced up
Been using an M42 10/14 Vari-Tooth blade from TuffSaws that is proving it's £16.00 cost over the standard 24tpi carbon steel type supplied with the bandsaw.
This supplier is often mentioned and praised, by those on the Model Engineer UK Forum
Just started on a late block, received from Jamie, and going be interesting to see the differences, but the first is the water gap between the cylinders, plus the valve guides are just about flush with the ports, unlike the early engine where they protrude into the ports quite significantly and no water gap between cylinders.
Geoff - A bit nippy in the Carport so play postponed for the day.
Cylinder block sliced up - by Geoff Halstead - 19-11-2017, 01:08 PM
RE: Cylinder block sliced up - by Nick Lettington - 20-11-2017, 02:11 PM
RE: Cylinder block sliced up - by Ken Morton - 21-11-2017, 05:27 PM
RE: Cylinder block sliced up - by Geoff Halstead - 25-11-2017, 04:09 PM
RE: Cylinder block sliced up - by Tony Betts - 25-11-2017, 04:13 PM
RE: Cylinder block sliced up - by Tony Betts - 25-11-2017, 06:36 PM
