  • 1 Vote(s) - 2 Average
Replacing cylinderhead
#51
At our shop we have had a number of head gasket related issues with Austin Healeys , MG Bs, Minis and other classic British cars which seem to be related to the type of head gaskets that are currently being sold as the replacements for the original OEM type. Some are better than others at sealing but those that don't have caused no end of issues with sealing. All of the engines in question were rebuilt with both the heads and cylinder top faces having been machined flat, new studs and nuts installed and the torquing of all the nuts done to spec.
What did work for us was a spray on gasket sealer designed for this type of application. A light coat applied on both surfaces as per directions and everything assembled  with all mating surfaces absolutely clean and dry.
A talk with your knowledgeable motor factor supplier should be able to advise you on the best product available in your country for this application.
Stephen
Replacing cylinderhead - by Paul Nott - 19-11-2019, 07:30 PM
RE: Replacing cylinderhead - by Alan - 19-11-2019, 07:35 PM
RE: Replacing cylinderhead - by Bob Culver - 19-11-2019, 07:49 PM
RE: Replacing cylinderhead - by Charles Levien - 19-11-2019, 08:12 PM
RE: Replacing cylinderhead - by Steve Jones - 19-11-2019, 08:17 PM
RE: Replacing cylinderhead - by Robert Foreman - 19-11-2019, 08:31 PM
RE: Replacing cylinderhead - by Chris KC - 19-11-2019, 08:40 PM
RE: Replacing cylinderhead - by JonE - 19-11-2019, 09:51 PM
RE: Replacing cylinderhead - by Roland Alcock - 19-11-2019, 10:07 PM
RE: Replacing cylinderhead - by Paul Nott - 19-11-2019, 10:49 PM
RE: Replacing cylinderhead - by Alan - 19-11-2019, 11:19 PM
RE: Replacing cylinderhead - by Davemayle - 19-11-2019, 11:58 PM
RE: Replacing cylinderhead - by Ian Williams - 20-11-2019, 05:18 AM
RE: Replacing cylinderhead - by Bob Culver - 20-11-2019, 06:10 AM
RE: Replacing cylinderhead - by Colin Wilks - 20-11-2019, 09:36 AM
RE: Replacing cylinderhead - by JonE - 20-11-2019, 09:48 AM
RE: Replacing cylinderhead - by Ian Williams - 20-11-2019, 07:37 PM
RE: Replacing cylinderhead - by Chris KC - 20-11-2019, 07:56 PM
RE: Replacing cylinderhead - by Paul Nott - 03-12-2019, 07:44 PM
RE: Replacing cylinderhead - by Charles Levien - 03-12-2019, 08:15 PM
RE: Replacing cylinderhead - by Alan - 03-12-2019, 08:56 PM
RE: Replacing cylinderhead - by AustinWood - 03-12-2019, 09:02 PM
RE: Replacing cylinderhead - by rubyman - 03-12-2019, 09:41 PM
RE: Replacing cylinderhead - by Steve Jones - 03-12-2019, 09:54 PM
RE: Replacing cylinderhead - by Charles Levien - 04-12-2019, 09:45 AM
RE: Replacing cylinderhead - by Paul Nott - 04-12-2019, 02:53 PM
RE: Replacing cylinderhead - by Paul Nott - 05-12-2019, 08:30 PM
RE: Replacing cylinderhead - by Steve Jones - 05-12-2019, 08:36 PM
RE: Replacing cylinderhead - by Chris KC - 05-12-2019, 09:11 PM
RE: Replacing cylinderhead - by Steve Jones - 05-12-2019, 09:15 PM
RE: Replacing cylinderhead - by Chris KC - 05-12-2019, 09:49 PM
RE: Replacing cylinderhead - by Alan - 05-12-2019, 11:13 PM
RE: Replacing cylinderhead - by Ian Williams - 05-12-2019, 11:24 PM
RE: Replacing cylinderhead - by Ian Williams - 06-12-2019, 07:57 PM
RE: Replacing cylinderhead - by Alan - 06-12-2019, 08:35 PM
RE: Replacing cylinderhead - by Steve Jones - 06-12-2019, 08:41 PM
RE: Replacing cylinderhead - by Malcolm Parker - 07-12-2019, 09:58 AM
RE: Replacing cylinderhead - by Ian Williams - 08-12-2019, 03:13 AM
RE: Replacing cylinderhead - by Paul N-M - 08-12-2019, 10:54 AM
RE: Replacing cylinderhead - by Charles P - 08-12-2019, 07:28 PM
RE: Replacing cylinderhead - by Ian Williams - 08-12-2019, 08:34 PM
RE: Replacing cylinderhead - by Rogerfrench - 09-12-2019, 04:08 PM
RE: Replacing cylinderhead - by JonE - 09-12-2019, 06:23 PM
RE: Replacing cylinderhead - by Ruairidh Dunford - 09-12-2019, 07:40 PM
RE: Replacing cylinderhead - by Ian Williams - 09-12-2019, 07:46 PM
RE: Replacing cylinderhead - by Ruairidh Dunford - 09-12-2019, 08:28 PM
RE: Replacing cylinderhead - by Ian Williams - 09-12-2019, 11:32 PM
RE: Replacing cylinderhead - by Ruairidh Dunford - 09-12-2019, 11:36 PM
RE: Replacing cylinderhead - by Ian Williams - 09-12-2019, 11:37 PM
RE: Replacing cylinderhead - by Steve Bryant - 10-12-2019, 02:26 PM
RE: Replacing cylinderhead - by JonE - 10-12-2019, 05:23 PM
RE: Replacing cylinderhead - by Ruairidh Dunford - 10-12-2019, 05:38 PM
RE: Replacing cylinderhead - by John Mason - 10-12-2019, 06:12 PM
RE: Replacing cylinderhead - by Paul Nott - 10-12-2019, 06:40 PM
RE: Replacing cylinderhead - by Renaud - 10-12-2019, 06:50 PM
RE: Replacing cylinderhead - by JonE - 11-12-2019, 09:19 AM
RE: Replacing cylinderhead - by John Mason - 11-12-2019, 10:23 AM
RE: Replacing cylinderhead - by Paul Nott - 11-12-2019, 05:25 PM
RE: Replacing cylinderhead - by Steve Jones - 11-12-2019, 05:33 PM
RE: Replacing cylinderhead - by Howard Wright - 11-12-2019, 05:40 PM
RE: Replacing cylinderhead - by Paul Nott - 11-12-2019, 07:58 PM
RE: Replacing cylinderhead - by Steve Jones - 11-12-2019, 08:14 PM
RE: Replacing cylinderhead - by Paul Nott - 11-12-2019, 08:32 PM
RE: Replacing cylinderhead - by Renaud - 08-04-2020, 12:16 PM
RE: Replacing cylinderhead - by Hugh Barnes - 08-04-2020, 01:42 PM
RE: Replacing cylinderhead - by Dave Mann - 08-04-2020, 09:45 PM
