24-11-2017, 10:15 PM
I use a 50% antifreeze not just as an antifreeze but also as a corrosion inhibitor. With this I found that the top early manifold joint was prone to weeping, even with flat faces and a new joint, and was only cured by using a sealant on the joint. i don't know it's name as it has long since disappeared from the tube.
