Hi Robert
That is a very elegant solution.
I’ve recently had a shortened Ruby shaft fitted with new ends.  At the flexible coupling end this was no problem just a large flange but at the torque tube end I’ve ended up with the pinion flange being re-drilled to fit a smaller 6 hole UJ flange.  It’s OK but not as good as your solution.
RE: What have you done today with your Austin Seven - by Howard Wright - 07-12-2019, 09:18 PM
Users browsing this thread: 22 Guest(s)
