Handedness of Replacement Halfshafts?
If that was the case, all half shafts should snap when you reverse ? If it were supposed that the keyway would fail, it should not as no load should be on it when the hub is lapped to the shaft and tightened correctly.
RE: Handedness of Replacement Halfshafts? - by bob46320 - 30-11-2019, 12:18 PM
