27-11-2019, 10:58 AM
Hi Colin, yes some ambiguity in the opening post but things usually become clear in further discussion.
Re grinding, an offset crank grinder is best, you set the throw and all pins will then have an equal throw.
I don’t particularly like the other type which follow the the worn pin and therefore don’t necessarily correct, or equalise the throw.
