Connecting rod length
#30
HI ZETO,
Unfortunately  ROGER gave the impression that he had change the position of the rods and still had the same result which I for one understood this to mean he had moved the centre two rods to the outside and still ended up with 20 thou protrusion on the pistons.
Now it would appear that the two out side rods were moved to the centre and still had 20 thou protrusion .
In this case a bit more clarity on the first post would have helped.
This is not a criticism of Rodger just something we all need to be aware of when trying to convey a problem that it can produce a misconception
Colin
NZ
Connecting rod length - by Roger - 25-11-2019, 02:39 PM
RE: Connecting rod length - by Chris KC - 25-11-2019, 03:15 PM
RE: Connecting rod length - by Roger - 25-11-2019, 03:44 PM
RE: Connecting rod length - by Chris KC - 25-11-2019, 03:53 PM
RE: Connecting rod length - by Roger - 25-11-2019, 04:33 PM
RE: Connecting rod length - by Geoff101 - 25-11-2019, 05:22 PM
RE: Connecting rod length - by Roger - 25-11-2019, 05:31 PM
RE: Connecting rod length - by Hugh Barnes - 25-11-2019, 05:51 PM
RE: Connecting rod length - by Roger - 25-11-2019, 06:02 PM
RE: Connecting rod length - by Howard Wright - 25-11-2019, 06:42 PM
RE: Connecting rod length - by Roger - 25-11-2019, 06:53 PM
RE: Connecting rod length - by Reckless Rat - 25-11-2019, 07:38 PM
RE: Connecting rod length - by Robert Foreman - 25-11-2019, 08:25 PM
RE: Connecting rod length - by John Cornforth - 25-11-2019, 08:56 PM
RE: Connecting rod length - by Roger - 25-11-2019, 10:43 PM
RE: Connecting rod length - by Tony Press - 25-11-2019, 11:13 PM
RE: Connecting rod length - by squeak - 25-11-2019, 11:55 PM
RE: Connecting rod length - by Zetomagneto - 25-11-2019, 11:56 PM
RE: Connecting rod length - by Bob Culver - 26-11-2019, 12:06 AM
RE: Connecting rod length - by Roger - 26-11-2019, 12:59 AM
RE: Connecting rod length - by Colin Reed - 26-11-2019, 01:45 AM
RE: Connecting rod length - by Bob Culver - 26-11-2019, 08:43 AM
RE: Connecting rod length - by Roger - 26-11-2019, 12:18 PM
RE: Connecting rod length - by Tony Press - 26-11-2019, 10:07 PM
RE: Connecting rod length - by Robert Foreman - 26-11-2019, 10:47 PM
RE: Connecting rod length - by andrew34ruby - 27-11-2019, 12:49 AM
RE: Connecting rod length - by Robert Foreman - 27-11-2019, 08:48 AM
RE: Connecting rod length - by Zetomagneto - 27-11-2019, 09:24 AM
RE: Connecting rod length - by Robert Foreman - 27-11-2019, 09:49 AM
RE: Connecting rod length - by Colin Reed - 27-11-2019, 09:58 AM
RE: Connecting rod length - by Zetomagneto - 27-11-2019, 10:58 AM
RE: Connecting rod length - by Roger - 28-11-2019, 11:28 AM
RE: Connecting rod length - by Howard Wright - 28-11-2019, 11:43 AM
RE: Connecting rod length - by Roger - 28-11-2019, 05:36 PM
RE: Connecting rod length - by squeak - 28-11-2019, 11:14 PM
RE: Connecting rod length - by Ian Dunford - 29-11-2019, 04:45 PM
RE: Connecting rod length - by Roger - 29-11-2019, 08:00 PM
RE: Connecting rod length - by Ian Dunford - 01-12-2019, 07:13 PM
RE: Connecting rod length - by Roger - 03-12-2019, 09:02 PM
