Connecting rod length
I would now number the pistons 1 to 4. Then remove them from the rods and measure the crown height from the gudgeon pin hole with a micrometer. They should all be the same.
  If the block isn't finally fitted you can also remove it and measure with a micrometer again to check the machining that has taken place.
Connecting rod length - by Roger - 25-11-2019, 02:39 PM
RE: Connecting rod length - by Chris KC - 25-11-2019, 03:15 PM
RE: Connecting rod length - by Roger - 25-11-2019, 03:44 PM
RE: Connecting rod length - by Chris KC - 25-11-2019, 03:53 PM
RE: Connecting rod length - by Roger - 25-11-2019, 04:33 PM
RE: Connecting rod length - by Geoff101 - 25-11-2019, 05:22 PM
RE: Connecting rod length - by Roger - 25-11-2019, 05:31 PM
RE: Connecting rod length - by Hugh Barnes - 25-11-2019, 05:51 PM
RE: Connecting rod length - by Roger - 25-11-2019, 06:02 PM
RE: Connecting rod length - by Howard Wright - 25-11-2019, 06:42 PM
RE: Connecting rod length - by Roger - 25-11-2019, 06:53 PM
RE: Connecting rod length - by Reckless Rat - 25-11-2019, 07:38 PM
RE: Connecting rod length - by Robert Foreman - 25-11-2019, 08:25 PM
RE: Connecting rod length - by John Cornforth - 25-11-2019, 08:56 PM
RE: Connecting rod length - by Roger - 25-11-2019, 10:43 PM
RE: Connecting rod length - by Tony Press - 25-11-2019, 11:13 PM
RE: Connecting rod length - by squeak - 25-11-2019, 11:55 PM
RE: Connecting rod length - by Zetomagneto - 25-11-2019, 11:56 PM
RE: Connecting rod length - by Bob Culver - 26-11-2019, 12:06 AM
RE: Connecting rod length - by Roger - 26-11-2019, 12:59 AM
RE: Connecting rod length - by Colin Reed - 26-11-2019, 01:45 AM
RE: Connecting rod length - by Bob Culver - 26-11-2019, 08:43 AM
RE: Connecting rod length - by Roger - 26-11-2019, 12:18 PM
RE: Connecting rod length - by Tony Press - 26-11-2019, 10:07 PM
RE: Connecting rod length - by Robert Foreman - 26-11-2019, 10:47 PM
RE: Connecting rod length - by andrew34ruby - 27-11-2019, 12:49 AM
RE: Connecting rod length - by Robert Foreman - 27-11-2019, 08:48 AM
RE: Connecting rod length - by Zetomagneto - 27-11-2019, 09:24 AM
RE: Connecting rod length - by Robert Foreman - 27-11-2019, 09:49 AM
RE: Connecting rod length - by Colin Reed - 27-11-2019, 09:58 AM
RE: Connecting rod length - by Zetomagneto - 27-11-2019, 10:58 AM
RE: Connecting rod length - by Roger - 28-11-2019, 11:28 AM
RE: Connecting rod length - by Howard Wright - 28-11-2019, 11:43 AM
RE: Connecting rod length - by Roger - 28-11-2019, 05:36 PM
RE: Connecting rod length - by squeak - 28-11-2019, 11:14 PM
RE: Connecting rod length - by Ian Dunford - 29-11-2019, 04:45 PM
RE: Connecting rod length - by Roger - 29-11-2019, 08:00 PM
RE: Connecting rod length - by Ian Dunford - 01-12-2019, 07:13 PM
RE: Connecting rod length - by Roger - 03-12-2019, 09:02 PM
