Connecting rod length
Hi Roger
I think that if you assemble the crank and rods out of the engine you should be able to thread a 1/2” silver steel bar through all of the little ends.  If you can’t then the rods are suspect.
However I doubt the rods themselves will be 20 thou out but the white metalling could have been bored incorrectly.
Sorry this check means you will have to disassemble the engine.
Connecting rod length - by Roger - 25-11-2019, 02:39 PM
RE: Connecting rod length - by Chris KC - 25-11-2019, 03:15 PM
RE: Connecting rod length - by Roger - 25-11-2019, 03:44 PM
RE: Connecting rod length - by Chris KC - 25-11-2019, 03:53 PM
RE: Connecting rod length - by Roger - 25-11-2019, 04:33 PM
RE: Connecting rod length - by Geoff101 - 25-11-2019, 05:22 PM
RE: Connecting rod length - by Roger - 25-11-2019, 05:31 PM
RE: Connecting rod length - by Hugh Barnes - 25-11-2019, 05:51 PM
RE: Connecting rod length - by Roger - 25-11-2019, 06:02 PM
RE: Connecting rod length - by Howard Wright - 25-11-2019, 06:42 PM
RE: Connecting rod length - by Roger - 25-11-2019, 06:53 PM
RE: Connecting rod length - by Reckless Rat - 25-11-2019, 07:38 PM
RE: Connecting rod length - by Robert Foreman - 25-11-2019, 08:25 PM
RE: Connecting rod length - by John Cornforth - 25-11-2019, 08:56 PM
RE: Connecting rod length - by Roger - 25-11-2019, 10:43 PM
RE: Connecting rod length - by Tony Press - 25-11-2019, 11:13 PM
RE: Connecting rod length - by squeak - 25-11-2019, 11:55 PM
RE: Connecting rod length - by Zetomagneto - 25-11-2019, 11:56 PM
RE: Connecting rod length - by Bob Culver - 26-11-2019, 12:06 AM
RE: Connecting rod length - by Roger - 26-11-2019, 12:59 AM
RE: Connecting rod length - by Colin Reed - 26-11-2019, 01:45 AM
RE: Connecting rod length - by Bob Culver - 26-11-2019, 08:43 AM
RE: Connecting rod length - by Roger - 26-11-2019, 12:18 PM
RE: Connecting rod length - by Tony Press - 26-11-2019, 10:07 PM
RE: Connecting rod length - by Robert Foreman - 26-11-2019, 10:47 PM
RE: Connecting rod length - by andrew34ruby - 27-11-2019, 12:49 AM
RE: Connecting rod length - by Robert Foreman - 27-11-2019, 08:48 AM
RE: Connecting rod length - by Zetomagneto - 27-11-2019, 09:24 AM
RE: Connecting rod length - by Robert Foreman - 27-11-2019, 09:49 AM
RE: Connecting rod length - by Colin Reed - 27-11-2019, 09:58 AM
RE: Connecting rod length - by Zetomagneto - 27-11-2019, 10:58 AM
RE: Connecting rod length - by Roger - 28-11-2019, 11:28 AM
RE: Connecting rod length - by Howard Wright - 28-11-2019, 11:43 AM
RE: Connecting rod length - by Roger - 28-11-2019, 05:36 PM
RE: Connecting rod length - by squeak - 28-11-2019, 11:14 PM
RE: Connecting rod length - by Ian Dunford - 29-11-2019, 04:45 PM
RE: Connecting rod length - by Roger - 29-11-2019, 08:00 PM
RE: Connecting rod length - by Ian Dunford - 01-12-2019, 07:13 PM
RE: Connecting rod length - by Roger - 03-12-2019, 09:02 PM
