  • 1 Vote(s) - 1 Average
CLUTCH QUESTION
#21
When I first bought my RP saloon, it suffered from clutch judder in reverse. The clutch also could be provoked into slipping on steep hills when changing from first to second.
The engine and box on a box saloon comes out in under two hours and, when I took the clutch to bits, the linings had, at some stage, been subjected to oil contamination which had baked into the linings, giving them a finish rather like that on a grand piano. Replacing the linings (which I had riveted into place by  firm specialising in commercial vehicle brake lining replacement) not only cured the clutch slip but the judder as well.
I never found out where the oil had come from. The clutch pit was dry (well reasonably) when I stripped it and has remained so ever since. I understnad that the gearbox is often the culprit, but mine, for all its faults, doesn't leak oil!
CLUTCH QUESTION - by Rpm - 10-11-2019, 07:02 PM
RE: CLUTCH QUESTION - by Colin Wilks - 10-11-2019, 07:09 PM
RE: CLUTCH QUESTION - by Rpm - 10-11-2019, 07:18 PM
RE: CLUTCH QUESTION - by Robert Leigh - 11-11-2019, 12:37 PM
RE: CLUTCH QUESTION - by Rpm - 11-11-2019, 03:50 PM
RE: CLUTCH QUESTION - by Colin Wilks - 11-11-2019, 04:31 PM
RE: CLUTCH QUESTION - by Chris KC - 11-11-2019, 04:47 PM
RE: CLUTCH QUESTION - by Ian McGowan - 11-11-2019, 05:13 PM
RE: CLUTCH QUESTION - by Rpm - 11-11-2019, 05:18 PM
RE: CLUTCH QUESTION - by Colin Wilks - 11-11-2019, 05:47 PM
RE: CLUTCH QUESTION - by Chris KC - 11-11-2019, 07:36 PM
RE: CLUTCH QUESTION - by Rpm - 11-11-2019, 10:05 PM
RE: CLUTCH QUESTION - by Rpm - 12-11-2019, 12:08 PM
RE: CLUTCH QUESTION - by Colin Wilks - 12-11-2019, 01:49 PM
RE: CLUTCH QUESTION - by Rpm - 12-11-2019, 03:18 PM
RE: CLUTCH QUESTION - by Peter Clayton - 12-11-2019, 04:31 PM
RE: CLUTCH QUESTION - by Rpm - 12-11-2019, 10:20 PM
RE: CLUTCH QUESTION - by Bob Culver - 12-11-2019, 10:30 PM
RE: CLUTCH QUESTION - by Howard Wright - 12-11-2019, 10:36 PM
RE: CLUTCH QUESTION - by David Stepney - 12-11-2019, 10:37 PM
RE: CLUTCH QUESTION - by Bob Culver - 13-11-2019, 04:47 AM
RE: CLUTCH QUESTION - by Rpm - 13-11-2019, 12:44 PM
RE: CLUTCH QUESTION - by Tom Coates - 13-11-2019, 01:24 PM
RE: CLUTCH QUESTION - by Rpm - 13-11-2019, 07:49 PM
RE: CLUTCH QUESTION - by Tom Coates - 14-11-2019, 08:53 AM
RE: CLUTCH QUESTION - by Rpm - 14-11-2019, 11:53 AM
