  • 1 Vote(s) - 1 Average
CLUTCH QUESTION
Hi Rpm
I think Peter is referring to the connection between the support bracket and the chassis.  I had ferocious judder when I first put the RK together. Then I found that you could move the whole support bracket up and down on the ball.  The big nut on the base of the support bracket needs to be tightened to ensure no vertical movement.
Regarding the big castellated nut tightness. The ball section of the torque tube does tend to wear in one place and it is difficult to judge how much to tighten the nut. Too tight and it can snag damaging the tube. If it is very slack you can remove the support bracket an shave a small amount off the face (1/16”?). The castellated nut should then tighten up a little more.
CLUTCH QUESTION - by Rpm - 10-11-2019, 07:02 PM
RE: CLUTCH QUESTION - by Colin Wilks - 10-11-2019, 07:09 PM
RE: CLUTCH QUESTION - by Rpm - 10-11-2019, 07:18 PM
RE: CLUTCH QUESTION - by Robert Leigh - 11-11-2019, 12:37 PM
RE: CLUTCH QUESTION - by Rpm - 11-11-2019, 03:50 PM
RE: CLUTCH QUESTION - by Colin Wilks - 11-11-2019, 04:31 PM
RE: CLUTCH QUESTION - by Chris KC - 11-11-2019, 04:47 PM
RE: CLUTCH QUESTION - by Ian McGowan - 11-11-2019, 05:13 PM
RE: CLUTCH QUESTION - by Rpm - 11-11-2019, 05:18 PM
RE: CLUTCH QUESTION - by Colin Wilks - 11-11-2019, 05:47 PM
RE: CLUTCH QUESTION - by Chris KC - 11-11-2019, 07:36 PM
RE: CLUTCH QUESTION - by Rpm - 11-11-2019, 10:05 PM
RE: CLUTCH QUESTION - by Rpm - 12-11-2019, 12:08 PM
RE: CLUTCH QUESTION - by Colin Wilks - 12-11-2019, 01:49 PM
RE: CLUTCH QUESTION - by Rpm - 12-11-2019, 03:18 PM
RE: CLUTCH QUESTION - by Peter Clayton - 12-11-2019, 04:31 PM
RE: CLUTCH QUESTION - by Rpm - 12-11-2019, 10:20 PM
RE: CLUTCH QUESTION - by Bob Culver - 12-11-2019, 10:30 PM
RE: CLUTCH QUESTION - by Howard Wright - 12-11-2019, 10:36 PM
RE: CLUTCH QUESTION - by David Stepney - 12-11-2019, 10:37 PM
RE: CLUTCH QUESTION - by Bob Culver - 13-11-2019, 04:47 AM
RE: CLUTCH QUESTION - by Rpm - 13-11-2019, 12:44 PM
RE: CLUTCH QUESTION - by Tom Coates - 13-11-2019, 01:24 PM
RE: CLUTCH QUESTION - by Rpm - 13-11-2019, 07:49 PM
RE: CLUTCH QUESTION - by Tom Coates - 14-11-2019, 08:53 AM
RE: CLUTCH QUESTION - by Rpm - 14-11-2019, 11:53 AM
