11-11-2019, 10:34 PM
Hi Jamie
Here’s two totally contradictory thoughts.
Try to avoid too many straight lines. IMHO the bonnet line should rise slightly from the radiator cowl. Echoing Duncan and Eric’s comments lower the radiator and “sweep” the bonnet line up to the windscreen. I would also lower the seat. In my current special build I am sitting on the floor with a minimal cushion!
What skills do you have regarding body building. If as suggested above you introduce more curves you are likely to end up with compound curves which are very difficult to clad unless you have some panel beating skills.
As I said contradictory!
