AC T type fuel pump problem
I incline to the same view as Nick, if fuel exits the hole below the diaphragm,  there has to be a hole in the diaphragm or, as has been said , in the casting.
Robin, I would stay with the original pump that appears to work and, if necessary, install a new ethanol proof diaphragm.
If it were mine, I would blank off the hole in the crankcase and use a SU electric pump ( as I actually do!!).
AC T type fuel pump problem - by Robin Oldfield - 05-11-2019, 01:00 PM
RE: AC T type fuel pump problem - by Tony Betts - 05-11-2019, 01:20 PM
RE: AC T type fuel pump problem - by andrew34ruby - 05-11-2019, 06:52 PM
RE: AC T type fuel pump problem - by Ian McGowan - 05-11-2019, 07:27 PM
RE: AC T type fuel pump problem - by Bob Kneale - 06-11-2019, 12:56 PM
RE: AC T type fuel pump problem - by Jeff Taylor - 06-11-2019, 03:49 PM
