Handbrake Rivets
Hi Matt
If you have a steady hand grind them off with an angle grinder.  If not a well sharpened cold chisel and a lump hammer works. This latter method is made easier if the rivets are loose enough to get the chisel under the head.
Good luck
Handbrake Rivets - by Matt_Harnden - 02-11-2019, 04:41 PM
RE: Handbrake Rivets - by Howard Wright - 02-11-2019, 05:52 PM
RE: Handbrake Rivets - by Stuart Giles - 02-11-2019, 06:40 PM
