Brake lever cotters
#22
hi tony,
good luck with the blocks.
mine took a massive amount of adjustments to get the patterns to work. its only a small block, but thats a large part of the problem. the process of producing the first batch, and the financial outlay cost me health problems mainly from stress. it also sent me old and grey early.
the heads got to the stage that producing a batch of 10 at a cost of £15,500 was just to much to put on the shelf. aas people were not prepared to give £2,000 for a new block. and if you have a problem with one block, YOU ARE IN THE RED.
GOOD LUCK.
as for the parts you are stocking from the uk, is a two pronged sward. i read the suggestion of measureing and drawing etc for new parts, and although the public may feel that makes sense? do remember the cotter pin sells for around £1.50 each. who is doing professional drawings for machine companies to work from at that price i dont know.
it is quality to price.
and as charles suggests, the quality is far better than 30 years ago.
id suggest the problem you have in quality of parts, is in half, because your supplier is a very large company. and cant keep up with quality to production of the number of items he is manufacturing.
the other half of the problem, as it has always been. is there are three items in manufaturing this job.
brake cam,
slip cotter,
brake arm,
these were usually made by at least two different manufacturers, and today likely to be made by 3 different manufacturers.
not of the three talk to each other, AS THE COTTER IS THE CHEAPEST PART,  the cotter has been make to fit the incorrect parts.
NO uk supplier can afford to throw away ill fitting parts.
tony
Brake lever cotters - by Tony Griffiths - 21-10-2019, 12:29 PM
RE: Brake lever cotters - by bob46320 - 21-10-2019, 01:05 PM
RE: Brake lever cotters - by Tony Griffiths - 21-10-2019, 01:51 PM
RE: Brake lever cotters - by JonE - 21-10-2019, 03:40 PM
RE: Brake lever cotters - by Tony Griffiths - 21-10-2019, 11:10 PM
RE: Brake lever cotters - by Tony Press - 21-10-2019, 11:25 PM
RE: Brake lever cotters - by Bob Culver - 22-10-2019, 04:37 AM
RE: Brake lever cotters - by Ruairidh Dunford - 22-10-2019, 06:59 AM
RE: Brake lever cotters - by Tony Press - 22-10-2019, 10:16 PM
RE: Brake lever cotters - by Tony Griffiths - 23-10-2019, 08:14 PM
RE: Brake lever cotters - by Tony Press - 23-10-2019, 10:18 PM
RE: Brake lever cotters - by Tony Griffiths - 23-10-2019, 10:36 PM
RE: Brake lever cotters - by Charles P - 23-10-2019, 11:46 PM
RE: Brake lever cotters - by Tony Press - 24-10-2019, 12:17 AM
RE: Brake lever cotters - by Charles P - 24-10-2019, 12:26 AM
RE: Brake lever cotters - by Tony Press - 24-10-2019, 06:57 AM
RE: Brake lever cotters - by Ruairidh Dunford - 24-10-2019, 07:21 AM
RE: Brake lever cotters - by Tony Press - 25-10-2019, 03:35 AM
RE: Brake lever cotters - by Ruairidh Dunford - 25-10-2019, 07:51 AM
RE: Brake lever cotters - by Tony Press - 25-10-2019, 10:58 PM
RE: Brake lever cotters - by Ruairidh Dunford - 26-10-2019, 08:23 AM
RE: Brake lever cotters - by Tony Betts - 26-10-2019, 11:59 AM
RE: Brake lever cotters - by Tony Press - 26-10-2019, 11:06 PM
RE: Brake lever cotters - by Tony Betts - 26-10-2019, 11:36 PM
RE: Brake lever cotters - by Tony Press - 27-10-2019, 12:07 AM
