24-10-2019, 07:44 PM
I have had this problem on a 31 banjo axle there are a couple of ways to correct it, put a shim behind the pair of thrust bearings, I used a piston ring or two from a twin rail and spacer oil ring. Use shims between the ball race and the pinion or machine off the six bolt torque tube flange or reface the banjo flange face, it depends how much you need to remove to get enough mesh. If you remove to much from the flange or shim the pinion to deep you can correct it with torque tube shims.
Terry.
Terry.
