12-10-2019, 09:39 PM
(This post was last modified: 12-10-2019, 09:41 PM by Tony Press.)
As I said seemingly ages ago in this rather interminable discussion-
'"And if you 'rotate' the Radius Arm end casting (probably a forging) outward at the top the castor angle can be set back - 5 degrees is said to be needed but anything over 1 degree helps with stopping the car from wandering ."
Although I mentioned Caster as in sugar which probably confused everyone
