Setting up Accuspark Distributor
Andy,
1. Take the ignition feed wire off the coil completely and attach it to the white wire coming from the new distributor n.b. I remove the ring connectors and make a soldered nipple joint for this connection.
2. Take the black wire from the new distributor and attach it to the (-) side of the coil.
3. Make up a new wire to attach to the (+) side of the coil and run this to earth.
Hope this helps,
Ruairidh
RE: Setting up Accuspark Distributor - by Ruairidh Dunford - 15-11-2017, 09:01 PM
RE: Setting up Accuspark Distributor - by JonE - 16-11-2017, 09:02 AM
RE: Setting up Accuspark Distributor - by JonE - 15-11-2017, 10:41 PM
RE: Setting up Accuspark Distributor - by JonE - 16-11-2017, 12:50 PM
RE: Setting up Accuspark Distributor - by GK5268 - 16-11-2017, 02:41 PM
RE: Setting up Accuspark Distributor - by JonE - 17-11-2017, 04:10 PM
RE: Setting up Accuspark Distributor - by JonE - 17-11-2017, 08:47 PM
