03-10-2019, 05:31 PM
(03-10-2019, 04:40 PM)Ruairidh Dunford Wrote: After this I throw the double springs as far as I can into the distance (or sell them to an enemy), buy a new set of single springs and fit them instead.
The last ones that I checked were no stronger in seat and nose loadings than standard single springs.
However having two coils of thinner gauge they were able to compress further without coil binding than standard ones, allowing their use with a higher lift cam.
But I'm with you in the idea of staying standard unless there's a good reason to go off piste.
Charles
