15-11-2017, 04:06 PM
Just to clarify, the front with the name on it can be rotated to close the hole off, but it falls back to the open position on its own, I am happy to remove and block it off if that's ok. On another note the engine has a finned aluminium sump fitted, large capacity I think, what will be the oil capacity of this as the dipstick can be pushed all the way down to the loop on the end even though it's loose in this position and I think it should be further up where it is a tighter fit. Thanks again.
