The Brookfields Special
#64
Spex.
Aluminium is nice and soft (usually, although Birmabright (the stuff Landrovers used to be made of) is brittle and extraordinarily difficult to work) and you can usually beat it into submission - eventually! It tends to work harden so needs to be heated to anneal it.
I don't know of anyone who lead loads now. Modern resin based body fillers will adhere to anything, including aluminium
You can even get a spray on body filler, although you need a special gun nozzle and it is imperative that the gun is THOROUGHLY cleaned immediately after spraying using the recommended cleaner.
I was, however, commenting on Duncan's stricture and not on Howard's approach.
The Brookfields Special - by Howard Wright - 13-07-2019, 06:27 PM
RE: The Brookfields Special - by Rick F - 14-07-2019, 12:38 AM
RE: The Brookfields Special - by Howard Wright - 14-07-2019, 08:39 AM
RE: The Brookfields Special - by JonE - 14-07-2019, 09:16 AM
RE: The Brookfields Special - by Howard Wright - 14-07-2019, 11:18 AM
RE: The Brookfields Special - by Ivor Hawkins - 14-07-2019, 04:29 PM
RE: The Brookfields Special - by Howard Wright - 14-07-2019, 06:16 PM
RE: The Brookfields Special - by Steve kay - 15-07-2019, 12:47 PM
RE: The Brookfields Special - by Howard Wright - 15-07-2019, 06:02 PM
RE: The Brookfields Special - by Howard Wright - 18-07-2019, 05:58 PM
RE: The Brookfields Special - by Terrytuned - 18-07-2019, 07:27 PM
RE: The Brookfields Special - by Howard Wright - 18-07-2019, 08:09 PM
RE: The Brookfields Special - by Terrytuned - 18-07-2019, 09:01 PM
RE: The Brookfields Special - by Howard Wright - 18-07-2019, 10:00 PM
RE: The Brookfields Special - by Howard Wright - 20-07-2019, 08:33 PM
RE: The Brookfields Special - by Howard Wright - 08-08-2019, 07:38 AM
RE: The Brookfields Special - by Duncan Grimmond - 09-08-2019, 08:10 AM
RE: The Brookfields Special - by Howard Wright - 09-08-2019, 09:51 AM
RE: The Brookfields Special - by AllAlloyCup - 09-08-2019, 04:08 PM
RE: The Brookfields Special - by phillips - 09-08-2019, 04:34 PM
RE: The Brookfields Special - by Duncan Grimmond - 09-08-2019, 10:05 PM
RE: The Brookfields Special - by Tony Press - 09-08-2019, 11:54 PM
RE: The Brookfields Special - by Duncan Grimmond - 10-08-2019, 09:39 AM
RE: The Brookfields Special - by Roger Goldthorpe - 10-08-2019, 09:46 AM
RE: The Brookfields Special - by Duncan Grimmond - 10-08-2019, 09:57 AM
RE: The Brookfields Special - by Mike Costigan - 10-08-2019, 12:43 PM
RE: The Brookfields Special - by Duncan Grimmond - 10-08-2019, 03:04 PM
RE: The Brookfields Special - by Malcolm Parker - 10-08-2019, 03:44 PM
RE: The Brookfields Special - by Duncan Grimmond - 10-08-2019, 03:53 PM
RE: The Brookfields Special - by stuartu - 10-08-2019, 05:26 PM
RE: The Brookfields Special - by Duncan Grimmond - 10-08-2019, 05:52 PM
RE: The Brookfields Special - by Barry - 11-08-2019, 10:03 PM
RE: The Brookfields Special - by Duncan Grimmond - 11-08-2019, 11:01 PM
RE: The Brookfields Special - by Howard Wright - 12-08-2019, 05:56 PM
RE: The Brookfields Special - by Ian Williams - 12-08-2019, 10:14 PM
RE: The Brookfields Special - by Duncan Grimmond - 13-08-2019, 12:08 AM
RE: The Brookfields Special - by Howard Wright - 13-08-2019, 07:35 AM
RE: The Brookfields Special - by Howard Wright - 20-08-2019, 01:23 PM
RE: The Brookfields Special - by Steve Jones - 20-08-2019, 01:47 PM
RE: The Brookfields Special - by Duncan Grimmond - 20-08-2019, 07:29 PM
RE: The Brookfields Special - by Howard Wright - 20-08-2019, 11:49 PM
RE: The Brookfields Special - by Howard Wright - 26-08-2019, 05:53 PM
RE: The Brookfields Special - by Nick Salmon - 27-08-2019, 02:53 PM
RE: The Brookfields Special - by Reckless Rat - 27-08-2019, 03:11 PM
RE: The Brookfields Special - by Nick Lettington - 27-08-2019, 03:19 PM
RE: The Brookfields Special - by Howard Wright - 27-08-2019, 06:30 PM
RE: The Brookfields Special - by Howard Wright - 31-08-2019, 06:56 PM
RE: The Brookfields Special - by Howard Wright - 13-09-2019, 06:49 PM
RE: The Brookfields Special - by Ian Williams - 13-09-2019, 09:28 PM
RE: The Brookfields Special - by Howard Wright - 14-09-2019, 06:55 AM
RE: The Brookfields Special - by Jamie - 14-09-2019, 11:29 AM
RE: The Brookfields Special - by Duncan Grimmond - 14-09-2019, 12:26 PM
RE: The Brookfields Special - by Howard Wright - 14-09-2019, 05:57 PM
RE: The Brookfields Special - by Duncan Grimmond - 14-09-2019, 06:24 PM
RE: The Brookfields Special - by Jamie - 15-09-2019, 09:34 AM
RE: The Brookfields Special - by Howard Wright - 21-09-2019, 06:33 PM
RE: The Brookfields Special - by Duncan Grimmond - 21-09-2019, 06:44 PM
RE: The Brookfields Special - by DavidL - 22-09-2019, 05:44 PM
RE: The Brookfields Special - by Howard Wright - 22-09-2019, 07:31 PM
RE: The Brookfields Special - by Duncan Grimmond - 22-09-2019, 10:29 PM
RE: The Brookfields Special - by DavidL - 28-09-2019, 10:20 PM
RE: The Brookfields Special - by David Stepney - 28-09-2019, 10:38 PM
RE: The Brookfields Special - by Spex - 28-09-2019, 10:51 PM
RE: The Brookfields Special - by David Stepney - 28-09-2019, 11:13 PM
RE: The Brookfields Special - by Duncan Grimmond - 29-09-2019, 12:26 AM
RE: The Brookfields Special - by Howard Wright - 29-09-2019, 07:51 AM
RE: The Brookfields Special - by Duncan Grimmond - 29-09-2019, 09:01 AM
RE: The Brookfields Special - by Howard Wright - 29-09-2019, 09:50 AM
RE: The Brookfields Special - by Duncan Grimmond - 29-09-2019, 01:36 PM
RE: The Brookfields Special - by Howard Wright - 02-10-2019, 06:46 PM
RE: The Brookfields Special - by Charles P - 02-10-2019, 06:57 PM
RE: The Brookfields Special - by Reckless Rat - 02-10-2019, 08:21 PM
RE: The Brookfields Special - by Howard Wright - 02-10-2019, 08:49 PM
RE: The Brookfields Special - by DavidL - 02-10-2019, 11:44 PM
RE: The Brookfields Special - by David Stepney - 03-10-2019, 12:07 AM
RE: The Brookfields Special - by Howard Wright - 10-10-2019, 06:41 PM
RE: The Brookfields Special - by David Stepney - 10-10-2019, 09:25 PM
RE: The Brookfields Special - by Duncan Grimmond - 12-10-2019, 06:00 PM
RE: The Brookfields Special - by Howard Wright - 12-10-2019, 06:46 PM
RE: The Brookfields Special - by Howard Wright - 20-10-2019, 06:41 PM
RE: The Brookfields Special - by Duncan Grimmond - 22-10-2019, 10:52 AM
RE: The Brookfields Special - by Howard Wright - 08-11-2019, 06:59 PM
RE: The Brookfields Special - by Nick Salmon - 08-11-2019, 07:23 PM
RE: The Brookfields Special - by Reckless Rat - 08-11-2019, 07:47 PM
RE: The Brookfields Special - by Duncan Grimmond - 08-11-2019, 09:51 PM
RE: The Brookfields Special - by Howard Wright - 23-11-2019, 05:26 PM
RE: The Brookfields Special - by Ashleyvincent - 23-11-2019, 06:23 PM
RE: The Brookfields Special - by Duncan Grimmond - 23-11-2019, 07:07 PM
RE: The Brookfields Special - by Dennis Nicholas - 30-11-2019, 01:11 AM
RE: The Brookfields Special - by Howard Wright - 30-11-2019, 10:22 AM
RE: The Brookfields Special - by Duncan Grimmond - 30-11-2019, 12:19 PM
RE: The Brookfields Special - by Howard Wright - 11-12-2019, 05:35 PM
RE: The Brookfields Special - by Duncan Grimmond - 11-12-2019, 09:03 PM
RE: The Brookfields Special - by Howard Wright - 20-01-2020, 07:33 PM
RE: The Brookfields Special - by JonE - 20-01-2020, 08:27 PM
RE: The Brookfields Special - by Dennis Nicholas - 21-01-2020, 05:29 PM
RE: The Brookfields Special - by Howard Wright - 29-01-2020, 07:13 PM
RE: The Brookfields Special - by JonE - 29-01-2020, 07:34 PM
RE: The Brookfields Special - by Howard Wright - 29-01-2020, 07:47 PM
RE: The Brookfields Special - by squeak - 29-01-2020, 11:21 PM
RE: The Brookfields Special - by Howard Wright - 01-02-2020, 08:49 PM
RE: The Brookfields Special - by Duncan Grimmond - 02-02-2020, 01:10 PM
RE: The Brookfields Special - by Greig Smith - 02-02-2020, 04:30 PM
RE: The Brookfields Special - by Howard Wright - 02-02-2020, 06:01 PM
RE: The Brookfields Special - by Howard Wright - 07-02-2020, 09:04 PM
RE: The Brookfields Special - by Chris Garner - 08-02-2020, 09:19 AM
RE: The Brookfields Special - by Duncan Grimmond - 08-02-2020, 06:41 PM
RE: The Brookfields Special - by Ruairidh Dunford - 08-02-2020, 06:52 PM
RE: The Brookfields Special - by Greig Smith - 08-02-2020, 08:42 PM
RE: The Brookfields Special - by Howard Wright - 08-02-2020, 10:11 PM
RE: The Brookfields Special - by Chris Garner - 09-02-2020, 11:24 AM
RE: The Brookfields Special - by Howard Wright - 09-02-2020, 02:39 PM
RE: The Brookfields Special - by Howard Wright - 20-03-2020, 08:38 PM
RE: The Brookfields Special - by JonE - 20-03-2020, 09:24 PM
RE: The Brookfields Special - by Howard Wright - 20-03-2020, 09:46 PM
RE: The Brookfields Special - by Mike Costigan - 20-03-2020, 10:13 PM
RE: The Brookfields Special - by Howard Wright - 20-03-2020, 10:17 PM
RE: The Brookfields Special - by Duncan Grimmond - 20-03-2020, 11:52 PM
RE: The Brookfields Special - by Howard Wright - 21-03-2020, 08:17 AM
RE: The Brookfields Special - by NBS - 21-03-2020, 08:38 AM
RE: The Brookfields Special - by JonE - 22-03-2020, 09:55 AM
RE: The Brookfields Special - by Colin Reed - 22-03-2020, 10:32 AM
RE: The Brookfields Special - by Howard Wright - 22-03-2020, 11:04 AM
RE: The Brookfields Special - by Duncan Grimmond - 22-03-2020, 12:23 PM
RE: The Brookfields Special - by Michael D - 22-03-2020, 02:15 PM
RE: The Brookfields Special - by Howard Wright - 30-03-2020, 10:41 AM
RE: The Brookfields Special - by Howard Wright - 17-05-2020, 05:54 PM
RE: The Brookfields Special - by Duncan Grimmond - 17-05-2020, 06:05 PM
