BRAKE PEDAL LENGTH
Hi Paul
Thanks for posting the photo.  I don't think you have a wedge in there but I do think BOTH clutch AND brake pedal are either non-standard or have been bent about a bit.  Strangely enough there seems to be a slot cut in the vertical floor section that would accommodate the correct lever.
I think your best bet would be to try and get standard levers and see how they fit?
Bruce.. I think your steering wedge is probably well thought out and it would be interesting to see a photo.  From posts on this forum I think it is not the norm.  Most wedges simply shunt the steering box upwards leading to the brake pivot being a bit higher.
BRAKE PEDAL LENGTH - by Paul Nott - 27-09-2019, 09:00 AM
RE: BRAKE PEDAL LENGTH - by Rick F - 27-09-2019, 09:55 AM
RE: BRAKE PEDAL LENGTH - by Chris KC - 27-09-2019, 10:24 AM
RE: BRAKE PEDAL LENGTH - by AustinWood - 27-09-2019, 11:27 AM
RE: BRAKE PEDAL LENGTH - by John Mason - 27-09-2019, 12:21 PM
RE: BRAKE PEDAL LENGTH - by Howard Wright - 27-09-2019, 03:01 PM
RE: BRAKE PEDAL LENGTH - by Bruce Nicholls - 27-09-2019, 05:03 PM
RE: BRAKE PEDAL LENGTH - by Paul Nott - 27-09-2019, 06:30 PM
RE: BRAKE PEDAL LENGTH - by Howard Wright - 27-09-2019, 06:46 PM
RE: BRAKE PEDAL LENGTH - by Greig Smith - 27-09-2019, 06:58 PM
RE: BRAKE PEDAL LENGTH - by Chris KC - 27-09-2019, 07:20 PM
RE: BRAKE PEDAL LENGTH - by daveg - 27-09-2019, 07:49 PM
RE: BRAKE PEDAL LENGTH - by Bruce Nicholls - 28-09-2019, 11:45 AM
RE: BRAKE PEDAL LENGTH - by Howard Wright - 28-09-2019, 07:54 PM
