/showthread.php 913 build_postbit
  • 1 Vote(s) - 4 Average
Vacuum Wiper - How to connect to inlet manifold, where to put the vacuum pipe
#63
Hello,
although the first self-made seal turned out to be useable and even worked, I will slightly alter the mould and make the seal open slightly more... the sides are simply to steep.
After fitting the seals and attaching the whole thing to a vacuum cleaner this is the result.... needs a bit of fine-tuning but it works!
Kind regards
Frank
RE: Vacuum Wiper - How to connect to inlet manifold, where to put the vacuum pipe - by Frank Stoll - 22-09-2019, 11:49 AM
