Nosepieces and shackles
Thanks Russell - the Companion shows two figures- 9 degrees (too much) and 5 degrees caster.
I would think that anything more than 1 degree will improve directional stability but too much makes the steering heavier.
With the early axle the radius arms can be easily twisted to set - later two bolt fixing arms are more tricky.
All angles are dependent on loaded angle of the chassis- high at the rear reduces the angle.
Nosepieces and shackles - by NBS - 18-09-2019, 10:19 AM
RE: Nosepieces and shackles - by stuartu - 18-09-2019, 12:33 PM
RE: Nosepieces and shackles - by NBS - 18-09-2019, 01:03 PM
RE: Nosepieces and shackles - by stuartu - 18-09-2019, 01:56 PM
RE: Nosepieces and shackles - by NBS - 18-09-2019, 04:43 PM
RE: Nosepieces and shackles - by dickie65 - 18-09-2019, 05:01 PM
RE: Nosepieces and shackles - by Bob Culver - 18-09-2019, 08:38 PM
RE: Nosepieces and shackles - by Ian Williams - 18-09-2019, 09:33 PM
RE: Nosepieces and shackles - by Tony Press - 18-09-2019, 11:21 PM
RE: Nosepieces and shackles - by NBS - 19-09-2019, 08:59 AM
RE: Nosepieces and shackles - by squeak - 19-09-2019, 11:06 PM
RE: Nosepieces and shackles - by David Stepney - 19-09-2019, 11:38 PM
RE: Nosepieces and shackles - by squeak - 19-09-2019, 11:56 PM
RE: Nosepieces and shackles - by Tony Press - 20-09-2019, 03:40 AM
RE: Nosepieces and shackles - by NBS - 24-09-2019, 12:08 PM
RE: Nosepieces and shackles - by JonE - 30-10-2019, 10:03 AM
RE: Nosepieces and shackles - by NBS - 30-10-2019, 12:05 PM
RE: Nosepieces and shackles - by Steve Jones - 30-10-2019, 12:46 PM
RE: Nosepieces and shackles - by Nick Turley - 30-10-2019, 09:58 PM
