kingpin greasing improvements?
Don't use grease. Use heavy oil (140 oil works well). Completely clear the pins of grease and fill it to the top with the oil. Refit the brass plug. With Girling pins, fill as above before fitting the top Welch plug. A small flip top oiler fitted into the grease nipple hole makes periodic topping up via an oil can easy.
kingpin greasing improvements? - by JonE - 19-09-2019, 08:11 PM
RE: kingpin greasing improvements? - by Steve Jones - 19-09-2019, 09:16 PM
RE: kingpin greasing improvements? - by David.H - 19-09-2019, 10:32 PM
RE: kingpin greasing improvements? - by JonE - 20-09-2019, 07:13 AM
RE: kingpin greasing improvements? - by David.H - 20-09-2019, 08:33 AM
RE: kingpin greasing improvements? - by David.H - 21-09-2019, 08:28 AM
RE: kingpin greasing improvements? - by JonE - 21-09-2019, 12:37 PM
