You should be able to feel approx where TDc is against the compression when the plugs are in or your thumb over the hole with plugs out. This will give you some confidence that the flywheel is marked correctly. I’m wondering if the timing is 180deg out. If you swap the middle two leads over and it starts and runs on two you’ll know it is.
