11-09-2019, 02:47 PM
Hi david,
If you meen the cost you have to pay. There's only one way to find out if it's worth it.
MAKE IT YOURSELF.
Time is most people's problem, they think they have plenty. But in reality, it all goes far to quickly.
If you can't make all the parts yourself, here are some individual parts prices from the seven workshops website.
4 x friction discs at £3.60 = £14.40
2 x nylon at £1.20 =. £2.40
2 x centre bolts at £8.34 =. £33.35
4 x star springs at £5.70 = £22.40
2 x pair of arms at £18.00 =£36.00 but you will need to shorten so you have time to add.
Total so far = £114.55
Then you start with the real part of the labour, you need to make the centre PLATE. Plus 4 discs to centre the fractions. And these are riveted originally.
Do be careful if you use 3mm centre plate, or even buy them with 3mm centre plate. There are some that have broken in the past.
The originals are 5mm plate, but for the cheaper opsion units offered 4mm plate is sufficient.
Please let us know if it's worth it, Tony.
MAKE IT YOURSELF.
