Ignition System Issue ???
(03-09-2019, 09:35 AM)Colin Wilks Wrote:
(02-09-2019, 09:30 PM)flywheel1935 Wrote:
(02-09-2019, 09:11 PM)Colin Wilks Wrote: https://aus7in.files.wordpress.com/2015/...wiring.jpg
Good wiring diagram by John Cornforth.
Best diagram so far, will be needing that once cars running ok again.
I must be missing something, but am left wondering why you don't install the car's ignition and charging wiring correctly and then get the engine running?
SIMPLES, the car is in bits !!!!! just need to run engine !!!!!!!!!!!!!
Ignition System Issue ??? - by flywheel1935 - 01-09-2019, 04:19 PM
RE: Ignition System Issue ??? - by David Stepney - 01-09-2019, 05:07 PM
RE: Ignition System Issue ??? - by flywheel1935 - 01-09-2019, 05:37 PM
RE: Ignition System Issue ??? - by Chris KC - 01-09-2019, 05:56 PM
RE: Ignition System Issue ??? - by David Stepney - 01-09-2019, 06:40 PM
RE: Ignition System Issue ??? - by flywheel1935 - 01-09-2019, 09:58 PM
RE: Ignition System Issue ??? - by Tiger - 02-09-2019, 02:48 AM
RE: Ignition System Issue ??? - by Colin Wilks - 02-09-2019, 08:03 AM
RE: Ignition System Issue ??? - by Zetomagneto - 02-09-2019, 08:06 AM
RE: Ignition System Issue ??? - by flywheel1935 - 02-09-2019, 07:22 PM
RE: Ignition System Issue ??? - by Bob Culver - 02-09-2019, 08:16 PM
RE: Ignition System Issue ??? - by Colin Wilks - 02-09-2019, 09:11 PM
RE: Ignition System Issue ??? - by flywheel1935 - 02-09-2019, 09:30 PM
RE: Ignition System Issue ??? - by Bob Culver - 02-09-2019, 11:46 PM
RE: Ignition System Issue ??? - by Colin Wilks - 03-09-2019, 09:35 AM
RE: Ignition System Issue ??? - by flywheel1935 - 03-09-2019, 04:42 PM
RE: Ignition System Issue ??? - by Colin Wilks - 03-09-2019, 05:56 PM
RE: Ignition System Issue ??? - by Steve Jones - 03-09-2019, 08:16 PM
RE: Ignition System Issue ??? - by Zetomagneto - 03-09-2019, 09:23 PM
RE: Ignition System Issue ??? - by flywheel1935 - 03-09-2019, 09:53 PM
RE: Ignition System Issue ??? - by Colin Wilks - 04-09-2019, 10:16 AM
RE: Ignition System Issue ??? - by flywheel1935 - 05-09-2019, 10:37 PM
