AC PETROL PUMP FITTING
For the T type pump the arm is 856955. I use this on a 2 bearing crank,but would think the 3 bearing has the same cam shaft.
Just checked another pump arm and it is numbered 1524079, this also works ok,so this could be yet another post that runs a while.
AC PETROL PUMP FITTING - by Rpm - 02-09-2019, 09:18 PM
RE: AC PETROL PUMP FITTING - by Nick Lettington - 02-09-2019, 09:48 PM
RE: AC PETROL PUMP FITTING - by Rpm - 02-09-2019, 10:11 PM
RE: AC PETROL PUMP FITTING - by Bob Culver - 02-09-2019, 10:43 PM
RE: AC PETROL PUMP FITTING - by Colin Wilks - 03-09-2019, 11:55 AM
RE: AC PETROL PUMP FITTING - by Bill Dixon - 03-09-2019, 12:17 PM
RE: AC PETROL PUMP FITTING - by Rpm - 03-09-2019, 01:33 PM
RE: AC PETROL PUMP FITTING - by Colin Wilks - 03-09-2019, 01:57 PM
RE: AC PETROL PUMP FITTING - by Rpm - 03-09-2019, 02:04 PM
RE: AC PETROL PUMP FITTING - by David.H - 03-09-2019, 05:32 PM
RE: AC PETROL PUMP FITTING - by Rpm - 03-09-2019, 05:57 PM
RE: AC PETROL PUMP FITTING - by Bob Culver - 03-09-2019, 08:02 PM
RE: AC PETROL PUMP FITTING - by Rpm - 03-09-2019, 09:43 PM
RE: AC PETROL PUMP FITTING - by Bob Culver - 04-09-2019, 01:19 AM
RE: AC PETROL PUMP FITTING - by Ian Williams - 04-09-2019, 07:03 AM
RE: AC PETROL PUMP FITTING - by Rpm - 04-09-2019, 10:40 AM
RE: AC PETROL PUMP FITTING - by Rpm - 04-09-2019, 08:21 PM
