Ignition System Issue ???
When tinkering with temp wiring lash up remember the dynamo if it can generate must lnk to the battery. So the output connection to cutout  should be in place and the battery fitted.
The situation with field and Dyn output linked but to nothing else must be avoided. This is the case in car with battery removed.
If connection(s) to the field terminal are removed the dyn will not generate, except for the  4 pole DEL type in rare original state.  For these, contrary to usual logic,  the terminls are best linked and directly earthed).
Ignition System Issue ??? - by flywheel1935 - 01-09-2019, 04:19 PM
RE: Ignition System Issue ??? - by David Stepney - 01-09-2019, 05:07 PM
RE: Ignition System Issue ??? - by flywheel1935 - 01-09-2019, 05:37 PM
RE: Ignition System Issue ??? - by Chris KC - 01-09-2019, 05:56 PM
RE: Ignition System Issue ??? - by David Stepney - 01-09-2019, 06:40 PM
RE: Ignition System Issue ??? - by flywheel1935 - 01-09-2019, 09:58 PM
RE: Ignition System Issue ??? - by Tiger - 02-09-2019, 02:48 AM
RE: Ignition System Issue ??? - by Colin Wilks - 02-09-2019, 08:03 AM
RE: Ignition System Issue ??? - by Zetomagneto - 02-09-2019, 08:06 AM
RE: Ignition System Issue ??? - by flywheel1935 - 02-09-2019, 07:22 PM
RE: Ignition System Issue ??? - by Bob Culver - 02-09-2019, 08:16 PM
RE: Ignition System Issue ??? - by Colin Wilks - 02-09-2019, 09:11 PM
RE: Ignition System Issue ??? - by flywheel1935 - 02-09-2019, 09:30 PM
RE: Ignition System Issue ??? - by Bob Culver - 02-09-2019, 11:46 PM
RE: Ignition System Issue ??? - by Colin Wilks - 03-09-2019, 09:35 AM
RE: Ignition System Issue ??? - by flywheel1935 - 03-09-2019, 04:42 PM
RE: Ignition System Issue ??? - by Colin Wilks - 03-09-2019, 05:56 PM
RE: Ignition System Issue ??? - by Steve Jones - 03-09-2019, 08:16 PM
RE: Ignition System Issue ??? - by Zetomagneto - 03-09-2019, 09:23 PM
RE: Ignition System Issue ??? - by flywheel1935 - 03-09-2019, 09:53 PM
RE: Ignition System Issue ??? - by Colin Wilks - 04-09-2019, 10:16 AM
RE: Ignition System Issue ??? - by flywheel1935 - 05-09-2019, 10:37 PM
