Ignition System Issue ???
(02-09-2019, 08:06 AM)Zetomagneto Wrote: "Independent of the car's ignition system," are you intending to bench run this?
Worse thing you can do to a newly bored engine.Get it in the car and drive it otherwise you will have glazed bores and subsequent excess oil consumption
EEEERR, I can't drive the car, because I can't get it to run, hence the "Independent of the cars ignition" All I need is a simple set-up to run it, so its live to + coil, earth via dizzy via - from coil if I understand correctly ?
Ignition System Issue ??? - by flywheel1935 - 01-09-2019, 04:19 PM
RE: Ignition System Issue ??? - by David Stepney - 01-09-2019, 05:07 PM
RE: Ignition System Issue ??? - by flywheel1935 - 01-09-2019, 05:37 PM
RE: Ignition System Issue ??? - by Chris KC - 01-09-2019, 05:56 PM
RE: Ignition System Issue ??? - by David Stepney - 01-09-2019, 06:40 PM
RE: Ignition System Issue ??? - by flywheel1935 - 01-09-2019, 09:58 PM
RE: Ignition System Issue ??? - by Tiger - 02-09-2019, 02:48 AM
RE: Ignition System Issue ??? - by Colin Wilks - 02-09-2019, 08:03 AM
RE: Ignition System Issue ??? - by Zetomagneto - 02-09-2019, 08:06 AM
RE: Ignition System Issue ??? - by flywheel1935 - 02-09-2019, 07:22 PM
RE: Ignition System Issue ??? - by Bob Culver - 02-09-2019, 08:16 PM
RE: Ignition System Issue ??? - by Colin Wilks - 02-09-2019, 09:11 PM
RE: Ignition System Issue ??? - by flywheel1935 - 02-09-2019, 09:30 PM
RE: Ignition System Issue ??? - by Bob Culver - 02-09-2019, 11:46 PM
RE: Ignition System Issue ??? - by Colin Wilks - 03-09-2019, 09:35 AM
RE: Ignition System Issue ??? - by flywheel1935 - 03-09-2019, 04:42 PM
RE: Ignition System Issue ??? - by Colin Wilks - 03-09-2019, 05:56 PM
RE: Ignition System Issue ??? - by Steve Jones - 03-09-2019, 08:16 PM
RE: Ignition System Issue ??? - by Zetomagneto - 03-09-2019, 09:23 PM
RE: Ignition System Issue ??? - by flywheel1935 - 03-09-2019, 09:53 PM
RE: Ignition System Issue ??? - by Colin Wilks - 04-09-2019, 10:16 AM
RE: Ignition System Issue ??? - by flywheel1935 - 05-09-2019, 10:37 PM
