02-09-2019, 02:23 AM
(This post was last modified: 02-09-2019, 02:32 AM by Mark McKibbin.)
Yes there is some oil coming from above mainly from the block to crankcase joint that will have to wait until pull the motor apart.
I will get rid of the spring washers and the plain washers and try fibre although the Dowty route may be the way to go. I also like the idea of studs but it might make it difficult to remove the sump in situ.
The sun has just come out so I might go for a drive to warm up the oil so I can change it, thanks for all the replies.
Mark
Mark
